Yanmar 3YM30 Engine & SD20 Saildrive Maintenance Information
I have collected information for the Yanamr 3YM30 engine and SD20 sail drive operation and maintenance used on the J/109. The following links should allow downloading information as PDF files. I keep these on a tablet computer for easy access and print the pages needed for a particular maintenance task.A handy list that allows easy reference for spare parts used is below:
Air Filter Yanmar # 128270-12540
Fuel Filter on Engine Yanmar # 104500-55710
Fuel Filter O-Ring Yanmar # 24341-000440
Fuel Filter (spin on) Racor R20P (2 micron)
Oil Filter Yanmar # 119660-35150 (cross reference to Fram PH3593A, Purolator PL14459, AC PF1127, Motorcraft FL-810, Castrol CMP3593A, Quaker State QS3593B)
Raw Water Pump Impeller Yanmar # 128397-42200
Raw Water Pump Cover O-Ring Yanmar # X02173476
V-Belt for 60Amp or 80 Amp Alternator Yanmar # 104511-78780
V-Belt for Fresh Water Pump and 110 Amp Balmar Alternator # 119831-42290 alternate part # Bando A-37.5 replaced by # 129612-42290
V-Belt for Raw Water Pump Yanmar # 104511-78780 (M19 Inch)
Saildrive Upper Zinc M20x50 Yanmar # 27210-200550
Saildrive Lower Split Zinc Yanmar # 196440-02660
Saildrive Lower Oil Seal Yanmar # 196313-02590 (Qty 2 required)
Saildrive Lower Seal O-ring Yanmar # 24321-000950 (Qty 2 required)
Saildrive Lower Drain Plug O-ring Yanmar # 24341-000125
cercole
Re: Yanmar 3YM30 Engine & SD20 Saildrive Maintenance Informa
Post by cercole »
Hi Bill,
Thanks for posting this. I'm going to download to my ipad later. I'm sure it will come in handy when I start commissioning the boat this spring.
fxalbert
Re: Yanmar 3YM30 Engine & SD20 Saildrive Maintenance Information
Post by fxalbert »
Wanted to let everyone know of a recent experience. I started my J 109 about a week ago and the "Water Proof" light came on and stayed on along with the warning buzzer. I figured it was probably the sail drive bladder warning and it was. After the yard did some examining and consultation with other Yanmar dealers on the east coast they determined it might be just condensation in between the exterior and interior bladders. After drying out the area they but the sensor back in and there was no more warning light. A week later still no warning light. Turns out a stretch of warm humid days can cause condensation to build up in there and the sensor (which is very sensitive) senses moisture not water.
