- Yanmar 3YM30 Operations Manual (January 2009)
- Yanmar 3YM30 Engine Service Manual (April 2005)
- Yanmar 3YM30 Engine Parts Catalog (June 2010)
- Yanmar SD20 Sail-drive Operations Manual
- Yanmar SD20 Sail-drive Service Manual
- Yanmar SD20 Sail-drive Parts Catalog
Air Filter Yanmar # 128270-12540
Fuel Filter on Engine Yanmar # 104500-55710
Fuel Filter O-Ring Yanmar # 24341-000440
Fuel Filter (spin on) Racor R20P (2 micron)
Oil Filter Yanmar # 119660-35150 (cross reference to Fram PH3593A, Purolator PL14459, AC PF1127, Motorcraft FL-810, Castrol CMP3593A, Quaker State QS3593B)
Raw Water Pump Impeller Yanmar # 128397-42200
Raw Water Pump Cover O-Ring Yanmar # X02173476
V-Belt for 60Amp or 80 Amp Alternator Yanmar # 104511-78780
V-Belt for Fresh Water Pump and 110 Amp Balmar Alternator # 119831-42290 alternate part # Bando A-37.5 replaced by # 129612-42290
V-Belt for Raw Water Pump Yanmar # 104511-78780 (M19 Inch)
Saildrive Upper Zinc M20x50 Yanmar # 27210-200550
Saildrive Lower Split Zinc Yanmar # 196440-02660
Saildrive Lower Oil Seal Yanmar # 196313-02590 (Qty 2 required)
Saildrive Lower Seal O-ring Yanmar # 24321-000950 (Qty 2 required)
Saildrive Lower Drain Plug O-ring Yanmar # 24341-000125
