Gebo Portlight Replacement Parts
US built hulls were supplied with Econoline Portlights manufactured by Gebo Marine Glazing in the Netherlands. I was unable to find a US supplier for replacement parts and corresponded with Gebo directly to get replacement rubber seals. They are able to supply parts for the opening portlights. Below are the numbers for various parts used on each type of portlight:
Three Opening Portlights installed - facing aft in head, facing aft in quarter berth, facing inboard in quarter berth
Note that two of these receive the most wear on the sealing rubber as many owners feed lines through the hatches while racing and wear the seal.
Acrylic Dimensions approximately 303mm x 124mm
  • 81.70.00.51 - Portlight Part Number
  • 89600611P - Sealing Rubber
  • 84.75.00.52 - Screen
Three Opening Portlights installed - main cabin port side forward and aft, main cabin starboard side forward
Acrylic Dimensions approximately 583mm x 124mm
  • 81.70.00.80 - Portlight Part Number
  • 89600611C - Sealing Rubber
  • 84.75.00.55 - Screen
One Fixed Portlight installed - main cabin starboard side aft over Nav Station
  • 81.71.00.80 - Portlight Part Number
Two Opening Portlights installed - facing outboard starboard side in head, facing outboard port side aft in quarter berth
Acrylic Dimensions approximately 259mm x 108mm
  • 81.70.00.70 - Portlight Part Number
  • 89600611H - Sealing Rubber
  • 84.75.00.50 - Screen
Parts that are stocked online include: The forward hatch is 500mm x 500mm and the hatch over the main cabin is 450mm x 320mm. Replacement parts for the hatches are at this link.
I contacted Gebo and asked that they include the seals in their online store at this link: http://www.yachtparts.com/
You may contact the following person for information or to place an order
Alan Bekendam - Email abekendam@gebo.com
Phone: 036-5211278
Gebo Marine Glazing BV.
Versterkerstraat 1
1322 AN Almere
Netherlands
fxalbert
Re: Gebo Portlight Replacement Parts
Post by fxalbert »
Just a note of caution. I know a lot of us have lines going into the head through the rear window and the rear cabin on the port side, again, though the rear window. Over time pulling the lines in and out wear down those gaskets. I just recently bought two, one for each side. They are 17 euros each. However shipping for them was 55 euros and Gebo would only accept a bank wire transfer for payment, another $25. All together for the two gaskets with the exchange rate, $127
fxalbert
Post by fxalbert »
I bought the two gaskets for the rear windows and with the international shipping they were VERY expensive. The kicker is although the interior widow frame comes off fairly easy I cannot see ANY way to get the actual window out to replace the gasket. It appears that the window was put in place using a marine caulk hopefully not 5200 but all of the sealants are VERY difficult to undo and I have for now given up on replacing the gaskets. If anyone has successfully removed one of these windows I'd love to know how you did it.
Frank,
I left the frames in place on the boat. The rubber seal was pulled towards the center of each frame to remove it from the machined grove it is pressed in. The new seal was lubricated with dish soap and inserted inch by inch into the machined groove. It takes some time, but it does work.
fxalbert
Post by fxalbert »
I am a little terrified to try that pull it out and inch by inch jam the new one in. Yikes! I can envision a LOT of trouble there.
Nickv
Post by Nickv »
I used these exact part numbers provided by Vento Solare and replaced every single port light gasket with an order from Gebo. The cost was ~$240.
I was able to pull out the old gasket using adjustable pliers. I then cleaned the area and simply soaped up the new gaskets and pushed them in as best as I could and then I closed the window and used plastic trim removal tools to properly push the gasket into the frame all the way.
I would imagine if you don't soap up the gaskets with dish soap, this would be way harder.
I no longer have any leaks from the port lights.
Mvallus
Post by Mvallus »
Curious if anyone has ordered a new forward hatch from Gebo? I emailed them and they sent me a brochure with many different styles (Standard/Flushline, with flange/without). I just want to make sure I get the right style and dimensions before I place my order.
https://www.gebo.com/en/deckhatches/
Mvallus
Post by Mvallus »
FYI, was able to install a new forward hatch (just the top). I can confirm the forward hatch is "Standard Deckhatch – no Flange (560 × 560mm)"; with cutout size of 500 x 500mm. https://yachtparts.com/product/standard ... -560560mm/
Could not order just the glass/top, had to order the entire thing.
svconfianza
Post by svconfianza »
Vento Solare wrote: Mon May 22, 2017 9:27 am I was unable to find a US supplier for replacement parts and corresponded with Gebo directly to get replacement rubber seals.
I am actually part of the new Gebo USA that's the North American distributor for Gebo. The Ecommerce store will be up shortly at https://www.gebousa.com, but in the meantime, please give me a shout if you guys need anything - amorris@gebousa.com or info@gebousa.com - (386) 243-5311
What is the process to replace the forward hatch? It came with no instructions.
What sealant is used?
Would it make sense to replace only the hatch top?
Dan Corcoran wrote: Fri Jul 26, 2024 2:21 pm What is the process to replace the forward hatch? It came with no instructions.
Do not use a silicone based caulk as you can never remove the residual if you ever need to replace the hatch again. Never use 5200 as it is not removable without significant destruction of the area since it bonds everything.
Suggest you use a polyurethane sealant such as Sikaflex 291, or an elastomeric sealant such as Total Boat Elastomeric Marine Sealant.
Wow, this was one of the quickest projects I have ever done, with a difficulty level of almost zero. The 291 is a pleasure to clean up, unlike 4200
An unfortunate update on the Gebo portlights ... after a change in ownership, Gebo slimmed its offerings and discontinued the "Econoline" port lights that were installed on J/109s. There are still some parts available, including the hinges set, handle set, and sealing rubber. The sealing rubbers are not made pre-formed anymore, so it’s only available to cut out sections that are not on a corner to make a repair.
Phoenix251
Post by Phoenix251 »
Just came across this same issue.
I ordered several feet of the sealing rubber earlier this year. It was a bummer they no longer carried the pre-formed seals. It was challenging getting wrinkles out of the seal while going around the bends, but it is possible.
First, clean out the old track very well. Mine had some hard sealant near the hinges. Then, using (and reapplying) soapy water, start halfway at the top and force the seal within the track. Corners are most challenging. I found doing this from inside the cabin provides a better angle. Once you have gone all the way around you will want to cut/shorten the strip to make things more manageable. At this point the corners will still look like garbage. To fix this, you need to stretch the seal within the track. Start by pulling the top tighter and try to spread the tension throughout. Do this a few times. I was surprised by how much it can stretch. Once it is tight enough the corners should have very little or no wrinkles. Cut the excess again to match the starting point.
My plan is to come up with some sort of 3d printed tube that will cover the seals and prevent chafe from lines. Will post if I have success.
